stuffing box
I have a 78 Hunter 30. Take a tip, go to Home Depot, Lowes or anywheres and get a set of picks. One of them has a hook on the end and another is straight. I had no luck using a screw as some have said. by the time you get a good grip, its tighten up the packing so it won't come out. On mine, I could do this in the water or out. Let it leak, the bildge pump can handle it. Isn't that bad. Be sure to use the right size packing and use the teflon type. Like your kitchen pans, it won't burn and works great. Alternated the seams around the shaft, be sure to cut each piece eactly the right length to go all the way around the shaft and alternate the end seems so they don't align up. you should be using at least 3 pieces, 4 if you can squeeze it in. Hand tighten the locking nut then give it a quarter turn more.
