Yanmar Starting Issue Solved
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Thanks to this forum which has substantial information on the subject.
My Yanmar 2GM20F always acted like it had a dead spot in the starter button on restart after sailing awhile, but never on an initial start. I finally decided to do something about it and read some of the forum discussions on the subject. The solution was certainly easy enough except for actually routing the wire from the panel to the starter.
The original wiring harness is probably all of 20 feet long, the excess length is bundled in a loop at the panel. The harness itself then goes aft to the transom then under the aft berth forward to the engine compartment. I simply disconnected the white wire at the push button and the starter and abandoned it. It appeared to be only about a 16ga wire and actually went through a couple of plug connecters in the harness before it got to the engine. I simply replaced that wire with a 14ga wire which I ran directly forward and down to the engine fishing it through a couple of factory access openings. That shortened the distance to about 10 feet.
In the process of re-connecting the wire, I also discovered that the primary cable to the starter was somewhat loose.Tightening that probably helped as well. That cable had not been touched in 7 years and engine vibration probably played a role in loosening it. Now the push button works like a charm.
Having read that others had installed a relay, which also makes sense, I would have done that next. But this certainly seems to have solved the problem.
Thanks to this forum and all of the input.
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
Good job, that's my next project. I'm looking at installing solar panels and will be routing those wires through many of the same areas so what's one more wire right?
Johnb
Hunter 37-cutter Richmond CA
Pleased to hear of your success. The starter solenoid on my Yanmar 3QM30 draws on the order of 20 amps (yes, I measured it) and with only a 12 volt supply it does not take much deterioration in the connections to result in it not working.
One advantage of a relay is that it will protect the switch in the engine panel from that current. The downside is an additional component and wiring.
Feb 21, 2011
74
Hunter 410 Lorain
Hi! We also had this problem on my 2000 H410. In my case - I started to have this problem after I replaced my starting battery with an AGM battery. Before doing any re-wiring - I decided to go back to the source and replace the AGM with a new lead acid battery. Problem solved! In over 50 starts - NO problems! Lesson learned! AGM batteries ARE different! Capt Bill on STARGAZER
