Hi All,
We are all familiar with running our diesel engines hard enough to keep them happy.
but...
What is hard enough?
What percentage of cruising speed RPM's should be the minimum?
My question comes from our cruise yesterday.
Mild wind, so we are motor sailing. We typically run our 29hp yanmar at 2800rpms per our dealers recommendation. So the wind picks up just a little, not enough to turn off the motor but enough to make me think about turning down the RPM's to conserve a 'little' fuel (i know it will be very little but that is not the point) but maintain the same speed. We drop the RPM's down to 2400 and continue to cruise around the same speed.
I am guessing that running 400RPM's lower won't be bad for the engine.
BUT...
when does it become bad? 70%, 60%, 50% of cruising speed?
does having the engine under load rather than idling at high RPM's change this answer?
All thoughts are always welcome.
thanks
Jack & Robin
but...
BUT...
thanks
Jack & Robin
