yanmar repower upgrade
mnydvr
Jan 26, 2009
10
caravell 20 nj
I want to replace my 1GM-10 with a bigger motor,she has a kanzaki trans,Im only looking for compaptment fit and trans fit,the rest is potatos and gravy for me,anybody know anybody to contact other than hunter.need help,I have a fabricator/glass man/mechanic waiting on a motor and would like to finish for summer.
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
Contact joe de Mars. Sound marine diesel for info on a beta kubota diesel. Red
Dec 2, 1999
15,184
How much horse power do you need for a 20' boat? Normal rule of thumb is 1hp/500 lbs. The old cherubini 30's only had 12 hp.
Is the 1gm bad?
Oct 26, 2008
6,277
Catalina 320 Barnegat, NJ
It seems odd that you just want more power unless there is some other reason for re-powering. How heavy is your 20' boat? The 1GM on my 5,700 # boat isn't bad for power but I am re-powering for other reasons.
The Yanmar 2YM15 is most compatable among the new engines. The footprint is just 2-inches longer with the same width, so the engine mount should already be close. The clearance is only slightly different and you can get an L elbow instead of the U if height is a problem.
Your transmission is compatable already if it is in good shape.
I also looked into the Beta but found a new one to be more expensive than Yanmar even when just comparing the bobtail straight-up (engine - no transmission). But when you factor in the need for a transmission (because your kanzaki won't be compatable) the price won't even be close. When you have to buy the tranny, the cost is way out of the ball park. Besides that, the mounts are all different and the hassle isn't worth it.
Replacing Yanmar with Yanmar is easily the best option. If you want a 1GM that should be repairable, we can talk. I have minor problems and we plan on repair or re-build once it is out of the boat in a few days. Once the 1GM is re-bored, it has the same bore as IGM10 ... I spoke to the folks at Mack Boring about this. Mack Boring is a great source of info because they are the distributor but they can't sell a Yanmar to you direct ... you have to go thru a dealer and there are many in the area.
