The basic rule of thumb, and considering hull design, is that you need about 2 hp per 1k lbs of displacement. My guess is that your boat displaces about 8,800 lbs so you should be looking for an 18 hp engine ... or so. Depending on the prop chosen, you could probably get by with a Yanmar 2GM20F, but I don't think I'd go with anything smaller.
