yanmar winterizing
i just did this and it is much simpler than you are thinking. you mneed a 5 gal. bucket,4 gallons of rv anti freeze,i 90 degree plastic fitting,probably 1/2 inch id, and 3 feet of same size rubber. simply unhook your filter/strainer. unhook the 3/4 inch line from the engine side of the strainer filter. put the 3/4 inch fitting in this line and add the 3 foot piece of the same size hose to the other end of the 90 degree plastic fitting. put the 4 gallons of rv in the 5 gallon bucket.,with the hose in to the bottom of the bucket. you may want to duct tape the hose into the bucket. now start your yanmar. the engoine will pull the antifreeze from the bucket much easier than it does when wet and pulling water through the strainer and into the engine. let this run until most of the 4 gallons is ran through the engine and out the exhaust into another bucket or, if biodegradable, onto the ground. better to catch it in an oil change pan or something similar. watch the level of the bucket. when most is gone through, simply shut off the engine. your yanmar is full of rv antifreeze as well as the discharge line and the jacket of the engine. when ready to get into the lake, do this again with clean water. this keeps the rv antifreeze out of the lake . you are ready to hook up your strainer and go sailing. whole process takes 10 minutes after starting. do not let antifreeze run out when filling engine. let warm up good so all water is gone and everything is full of antifreeze. bill from yacht basin showed me this as i am a first time yanmar owner, never gas again
