I just purchased a 1978 H27. I had recently asked about waxing the boat but now I have a bigger problem. I had the boat put into the water and took it out for a test run with the motor. I went about 2 miles when the motor just quit. It first started loosing power and then just quit. We tried to start it and broke the key off. We then hot wired it and notice that the head gasket was blown. I trying to figure out what went wrong. The boat use to be in salt water and now is in fresh water. I pulled the head and didn't notice anything strange. I will check with a straight edge for a warped head. Im also checking the thermostate to see if its opening.Does anyone any suggestions on what to check both for the key(Which is new) and the engine ???
Dave Jackson South Hero Vermont
