Yanmar manual mixing elbow maintenance
Oct 30, 2011
542
klidescope 30t norfolk
The "u" as described is for boats with the motor below the water line it keeps water from backing up into the engine
Jul 7, 2004
8,525
Hunter 30T Cheney, KS
That makes sense but I don't think my motor is that low. It rests behind the companionway stairs.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I think if it has the U type setup than it must be needed,me I would not want to take the chance of water backing up into the engine.
Nick
Mar 11, 2015
357
Hunter 33.5 Tacoma, WA
A good reason to NOT buy a SS knock off: I took my original 2GM20F elbow+coupler+riser to the yanmar parts center and THEY took the old unit back to their shop and THEY removed the old riser and replaced it with the new. They also said to bring it in every 3 years and the'll clean it for free.
BTW: Disconnecting the exhaust hose was tricky, but this is how I did it.
1) Remove the SS hose clamp
2) Disconnect the 4 elbow bolts to the exhaust manifold and the injection hose
3) Using a heat gun, heat up the exhaust hose around the top
4) Using WD40, spray around the hose
5) After a while, using a small flat screwdriver, carefully drive it in about 1/2 inch all around the hose
Reheat the hose. Spray more WD40, let it pool around the top and let it seep in. Drive the small screwdriver in deeper. Repeat. After a while, using the elbow+coupler+riser as leverage, try to twist the hose. After a while, it will twist and separating the hose and unit will be possible.. Then take the whole unit to the dealer! That's it... Worked for me!
Apr 22, 2011
971
Hunter 27 Pecan Grove, Oriental, NC
Justin, this pic illustrates how the design of the stock Yanmar GM mixing elbow directs the flow of raw water down and away from the exhaust manifold. It also shows how the buildup of crud restricts the flow of water. The other thing it does is elevates the mixer high enough to prevent back flow of water into the exhaust manifold. If water does get into the manifold and any of the exhaust valves are open, then water gets into the cylinder.... not good.
I'm not saying that your ss would not work. It looks like there would be less restriction for water and exhaust flow and less opportunities for corrosion. Just make sure your engines exhaust pipe is routed so there is no chance of ocean water backing into the mixer when the engine of off. And avoid trying to start the engine for a long period of time with the raw water seacock open.
Likes: Justin_NSA
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Looking at the cutaway elbow, I am surprised by the restriction in the exhaust. It looks like the effective diameter of the exhaust is halved at the threaded fitting,then halved again just before the water inlet into the exhaust stream. Mathematically that would initially cut the cross sectional area by a factor of 4 and then a factor of 4 again. That seems to me like it would strangle the engine. Apparently Yanmar doesn't consider that to be a problem.
Jul 7, 2004
8,525
The is a great cutaway picture! It definitely shows how restrictive they get by design and by lack of regular maintenance. We don't have anyone around here with the customer service mz4wheeler has. I'm not convinced that with the exhaust thruhull right at the waterline that I need the extra 4" lift that the U-type provides is necessary. Seem like plenty of rise with the straight version to allow the water to drain properly and not find a way back into the engine thru the exhaust. I will try to find some history on the Yanmar/Hunter setup.
