Probably the same routing and location as the H31. The panel is on the port, and the kill push-pull cable is exposed to the elements protruding from the panel. In my case, as the cable aged, it became harder to pull. It finally stressed and cracked the panel housing. The cable is routed from the panel turning sharply to starboard under the pedestal, into the starboard locker where it takes a wide arc to the starboard side of the engine.
I decided to move the cable to about the same location as the panel, but on the starboard locker. I cut a hole in the locker to accept a standard stainless sink drain. I added some stainless fender washers the same OD as the cable at the bottom of the drain to accommodate the cable. This creates a watertight recessed housing for it. It (1) keeps the cable drier (2) keeps it flush with the locker so it's out of harms way and (3) reduces the chance of binding by allowing a much straighter and shorter cable run to the engine.
