Yanmar engine panel
Feb 28, 2006
79
Hunter 34 610 Narragansett Bay
All,
Looking for the Yanmar engine instrument/control faceplate located in the cockpit. Mine was damaged when someone stepped on the engine pull/kill knob. I've had no luck with a glue repair so would like to replace or ???? Any suggestions and thank you.
Dec 14, 2003
1,403
All,
If you are looking only for the faceplate, they are not overly expensive and you should contact the Yanmar dealer in your area. Mack boring might be of some help also. Good luck
Jul 28, 2013
126
Hunter 34 Holland, Mi
When replacing the faceplate it is also a good time to replace the engine stop cable. They are not very costly and you have to take it loose at the engine to replace the panel.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
This is how a small job grows::). I would also suggest moving the stop cable off the instrument panel. This is often what causes the panel to become cracked- if the cable gets a bit corroded, when you pull it that puts a lot of stress on the corner screws of the panel. I moved mine to the solid fiberglass just to the left of the panel. I used large ss washers bedded to the glass both inside and outside to back the hole.
Jan 4, 2007
406
Hunter 30 Centerport
Torrensen Marine in Michigan should have the replacement parts. I've used them for years and they are very helpful. Heres the email and phone
www.torresen.com\
3003 Lakeshore Dr, Muskegon ·
(231) 759-8596
Dec 2, 1999
15,184
You can only purchase Yanmar parts from an authorized dealer/distributor in your region.
I believe that Mack Boring is the distributor but there are several dealers in your area.
http://us.yanmar.com/where-to-buy/
I would agree about the fuel shut off cable. This is often the reason that many of the "face plates" need to be replaced.
Jul 28, 2013
126
You should order a new panel gasket as well since you'll have it apart. I think they are around 5 or 10 dollars. Torrensen marine is a good source for parts. I use them but they are my local distributor. I wish I had known about the cable relocation when I did mine.
Dec 2, 1999
15,184
I relocated my fuel shut off to the top of the engine compartment on my H'31. If we are in a strange port I would pull it so the engine would not start. Not a bad security thing to fight the thieves.
May 24, 2004
7,132
CC 30 South Florida
Panel templates are relatively inexpensive and should be available at your parts distributor from Yanmar.
splax
Nov 12, 2012
692
Hunter 34 Portsmouth
When I replace my cracked panel, I hope to change the engine (fuel?) cut-off pull knob to the electric servo to eliminate the issue of pulling the cable and stressing the panel.
Jun 27, 2004
113
Hunter 34 New Bern, NC
I would suggest re-routing your engine stop cable when you replace the faceplate. On my Hunter 34 the stop cable was poorly routed, probably because Hunter routed it before they put the deck on the boat.
A better routing will send it between the deck and hull liner. You should also consider installing it to the left of the panel, because the panel is not strong enough to stand up to pulling on it.
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Yep, same here. I relocated the pull to the starboard side, which allowed me to shorten the cable quite a bit because on the H31 it's a pretty straight run from there to the engine. To prevent anyone stepping on the pull, I recessed it into the laz. To house the new stainless T-handle I used a stainless sink drain which already comes with a washer, has a nice mounting lip and large nut. Under $15 if you already have the hole saw.
Jun 1, 2009
1,755
Hunter 49 toronto
Definitely !!!
Get rid of the stop cable and go to electric stop. A really low cost retrofit
Here are the reasons
No salt & rust gumming up the stop cable
Easier to shut down
Less stress on panel
100% recommend this
Aug 16, 2009
1,000
Even if I went with a solenoid, I would want a manual backup for the kill switch. Here is a picture of my relocated recessed cable pull. Have not yet finished cleaning the caulk from around the installation.
303
Hunter 28.5 Jordan, ON
Belt and suspenders planning is great, but a reasonable backup to the electrical solenoid is to hop down and move the cutoff lever by hand if the primary method fails.
I definitely would not want the downsides of both remote systems if I were going to bother upgrading (getting rid of the original solution is half the reasoning behind doing so).
20
Hunter 36_80-82 -
Bought the panel housing and gasket from Torresen last July for 35.92 plus shipping. They don't ship to all states, however. Can't remember why but I had to have it delivered to my son's address a state away.
Sep 14, 2013
30
Hunter 34 Seattle, WA
Stop Cable
Does the H34 require the 3 or 4 meter version of the stop cable?
zds
Oct 28, 2008
110
Hunter 34 -
My records show that I replaced mine with:
qty : 1, manufacturer: Yanmar, part number : 104271-67550, description : Engine Stop Cable, 10 Feet, total price : 24.78
