Don H.
My 1992 Hunter Legend 37.5 has a Yanmar 3HM35F diesel that has always leaked a few drops of diesel fuel at the "banjo style" fuel line fittings on the fuel filter housing. The problem seems to be that Yanmar uses copper washers as gaskets on these "banjo" fittings. They stay tight and dry for about four or five uses of the engine, but they loosen. I've replaced the washers with new "Yanmar issue" washers. I continued tightening the fitting until the threads finally stripped out of the fuel filter housing (so I had to buy a new one for $50). This problem would be devastating if it were a gasoline engine (i.e. explosive fumes from raw gasoline in the engine sump pan.) With the diesel fuel it is more of a niusance than a safety issue. About 5 drops of diesel fuel leak out of these fittings into the engine sump for every engine hour. It also makes the cabin smell like diesel fuel.I've looked at my friend's 1996 Hunter Legend 37.5 and found that he has a different Yanmar. The fuel filter is up on top away from the heat of the engine block and has a large spin-on fuel filter instead the small insert type filter that I have. There is no fuel leakage from his filter fittings.I consulted one Yanmar diesel mechanic and he advised that my model always leaks a few drops of diesel fuel from the fuel filter. I've lived with it for the last 750 engine hours, but it sure would be nice to get rid of this fuel leak. Any suggestions?
