I posted a question on this earlier but I need some more info.
I have a tach for the diesel that reasd exactily half of the actual RPM.
I checked the sensor and put new connectors on them but no luck. Does anyone have any info on taking the wires from the tach direct to the alternator instead of buying a new sensor, which I may or may not need? Or does anyone know what the proper value would be if checking the sensor with an ohm meter?
I also want to run a water temp gage up at the control panel in the cockpit. I already have one down on the side of the engine enclosure. Does anyone have any info on a dual sensor for this? I already have a "T" someone put in the line so I could have the temp sw and one gage on it and don't want to add another fitting if I don't have to.
Thanks.
Thanks.
