Yanmar coolant fluid change
Mar 27, 2021
176
Hunter 306 Lake Pepin
...it looks like we have a hose spigot installed on one of our water heater lines. Do you think they did this and ran water through the system while dumping the coolant out through the engine ports to clear the system? I do like the air mattress pump idea to clear the water heat lines. Thoughts?
I had the same question last fall when I changed my 2GM20F coolant. It has the exact same setup as yours with the hose fitting on the water heater line. I searched but couldn't really find a clear answer for how it's supposed to be used, but ended up buying some hose fittings and trying out exactly what you suggested. It was a bit of a balancing act because I was nervous about over-pressurizing the cooling system with high pressure dock water. I don't think I would've impressed anyone and I probably won't try it again. I also used the air mattress pump trick to blow water out and that was more of a clear winner.
I also remember a suggestion that the hose fitting was for bleeding out air, but I didn't have enough extra hose to raise the fitting above the engine for that, so I just pulled the hose off at the engine freshwater pump and after filling the coolant reservoir, I would fill the water heater hose to the top before quickly inserting it back onto the freshwater pump. That seemed to work well enough despite some spillage. So far so good as I haven't overheated (yet).
I'd still be interested to hear of the proper way to use that water heater fitting before I make another attempt at pushing dock water through all my engine gaskets.
Sep 11, 2019
168
Hunter 386 Lake St. Clair
Thanks for getting back. No other replies yet. I did change the coolant last year in the engine, so I'll probably tackle this in the fall. The local Yanmar service guy wants $450 - $550 to change the coolant and thermostat. Ridiculous. Maybe I'll post something at the marina bulletin board and someone can give some advice on this. Keep you posted.
Mar 27, 2021
176
... I did change the coolant last year in the engine, so I'll probably tackle this in the fall. The local Yanmar service guy wants $450 - $550 to change the coolant and thermostat. Ridiculous. ...
Agreed on the price of a coolant flush. :eek:
Keep in mind though, that while you drained the coolant from the engine, the quart or whatever it is that was left in the hot water heater is now mixed with the new coolant you added. Not a huge deal if the two coolants are the same, but if the old and the new coolants are not compatible, you might want to move the full system coolant flush-and-fill up a little higher on your maintenance schedule. Proper coolant selection is an arcane art that I never mastered and I still wake up screaming in the middle of the night.
Sep 11, 2019
168
Yep, no worries there. The previous owner had left a jug of the coolant he used on the boat.
Jun 25, 2004
490
Hunter 306 Pasadena MD
Can I ask, please, what's the point of the "use distilled water for flushing in between"? If you only have to water in there long enough to bring it up to temp, why would you care if it's distilled or tap water? Thanks in advance for your explanation.
Mar 27, 2021
176
Because if you don't use distilled water the heat exchanger gods will get angry and smite you with 40 years of sludge. Apparently.
