K
Ken Bell
The 3GM-34 Yanmar Diesel in our Hunter 37 has required that I use the compression release several times of late to start. in the 3 seasons that we've owned it, I've had to do this when it has sat without use for several weeks, but recently it requires it even when it has not been shut down for long, twice when starting up after a few hours of sailing. The engine starts and runs fine when the compression release is used. there are no other indications of a problem (overheating, exhaust smoke, rough idle, etc)A couple of questions from someone who is a Diesel neophyte:1. Is this an indication of the engine needing attention (injectors, battery...)?2. Is there something that I could be doing on shutdown that will avoid this?3. If this is normal operation, why isn't there a compression release at the engine panel vice requiring two people to complete the start process (one at the helm, and one below, in the galley holding and releasing the compression release)? Has anyone added a compression release cable at the helm? How difficult is this?Thanks for your help.
