Yanmar 4jhe won't start after anchor line caught in prop.
Hi,
I'm new here and to diesels, and would like some assistance diagnosing my issue.
The short version is this:
1. Anchor line got about 8 wraps on the prop shaft and stopped the engine.
2. In "muscling" the shifter, I believe the cable snapped, but I can shift it by hand on the transmission.
3. I believe I have it in neutral.
4. When I turn the key there is power, the starter attempts to turn. If you say "grrrunt" out loud, thats about what it sounds like, and about as long as it tries to turn (.5 to 1 second)
5. I could turn the fly wheel with a wrench without too much trouble, but it is stiff.
I've googled and read a bunch but haven't heard of this problem.
It sounds like my lawn mower when it had super high compression and needed the valves reset.
Could there be another neutral sensor that won't let the engine crank until its in neutral?
Could air or a clog in the fuel line cause these symptoms?
Thanks for any help, and I'll be glad to add more info...
Alex
Hi,
Alex
