David Whitworth
I finally have some info from Yanmar about the problem of Hunter 33 Yanmar 3YM30's overheating above 2800 RPM. My boat is going to be fixed as a result of two Yanmar "Marine Service Advisories" (MSA's). The technical details are: Yanmar MSA # E05-023 for the diagnosis, and MSA E05-025 for the solution and parts spec. Engines with serial numbers lower than (but not including) E05566 are all affected.These MSAs are apparently difficult for your dealer to find. My dealer found out about them at a seminar - he was not notified through the regular channels.The diagnosis is twofold. First the heat exchanger does not effectively cool the engine over 2800 RPM - especially if clogged with bad gunk due to overheating of the coolant. Second the alignment of a hose at the end of the unit can cause a bubble to form. This bubble will move to the coolant pump when the engine gets hot and cause the pump to cavitate.The solution is to a) fix the hose problem and b) install a new design of heat exchanger core which has more tubes. The end caps and O-rings are also replaced and I understand that the end caps have also been redesigned.The delivery time for the new parts is four to six weeks and I expect to have my boat fixed (all under warranty) by the end of January. I will post a note here about the results at that time.The symptoms in the diagnosis exactly explain my boat's problem - overheating after 10 to 20 minutes over 2800 RPM. I am pretty sure this has identified the issue. Whether the new parts solve it . . . time will tell.While this has been a topic of concen to Hunter owners, there is no reason to suppose that it is a problem only on Hunter boats - unless the very tight installation on the 33 is a contributing factor. I note here that when I ran my test routine without the companionway steps installed I did not experience the overheating.
