Yanmar 3YM30 coolant drain plug question
Vegas
Feb 12, 2009
137
Beneteau 37 JBM, St. Clair Shores, MI
See the drain plug, circled "B" on the diagram. How do you pull that out? Is it threaded? If so I don't see a screwdriver slot in it..... or do you simply pry it out with a screwdriver? The metal clip that seems to be holding it has deteriorated. Can I replace it with a small radiator hose clamp?
This came up as I am troubleshooting my first ever "hot engine" alarm.
1,505
There's an Allen set screw in there. Get your Allen set and unscrew it.
SFS
Aug 18, 2015
2,091
Currently Boatless Okinawa
That hose can become clogged with sand, etc. The only time I have ever had reduced flow of exhaust water, I shut down and anchored, disconnected that hose at the pump, and found I had no water from the thru-hull. I cleared a LOT of sand from the hose, using (very judiciously) a long screwdriver.
Sep 20, 2006
2,953
There is also a seawater drain cock on the engine block at the back of the heat exchanger. In my manual it is under "Before you Operate" section.
Vegas
Feb 12, 2009
137
Thank you! I'll try it when I get back to the boat this weekend.
I hadn't seen the "allen wrench" configuration on the bottom of the plug.....guess I better wear my reading glasses next time!!
May 12, 2004
1,505
I missed it the first time. It's quite small. Needed my cheaters.
Jun 21, 2004
3,104
Beneteau 343 Slidell, LA
It is a metric size Allen wrench. Just drained & flushed my entire system a few weekl ago!
Slider
Sep 1, 2014
99
Beneteau 37DK Alameda
Just a note! when trying to open the drain the plug insert turned in the hose,so was unable to get the plug out. Use pliers to hold the hose and exert extra pressure to allow the set screw to come out with the allen wrench. Job done!
