jim oursler
Has anyone had a problem with the rubber sea water pump working fine at low speed, then failing at high speed? engine overheats at high speed, not a low rpms. A friend has suggested that the seawater pump impeller blades may be weak... looks good but at high speed may not handle the water volume. I've replaced thermostat, completely torn apart the heat exchanger, flushed raw water intake, checked anti freeze level. Boat has always been in freshwater. Any ideas?
