N
Neil
My 3GMF Yanmar leaks fuel and it appears to be coming from the almost inacessible fuel pump. Rather than work on the pump in place, it seems to be a better idea to remove it first and then work on it on the bench. It appears to be attached to the side of the engine block with a couple of bolts. If I remove these bolts and pull the pump, am I going to have any re-installation challenges?
