Zincs in fresh
Ok, here I go again playing the role of the targetable heretic and maybe perhaps with good cause, but since this is a free forum for ideas, here's my usual 2-cents so take it for what it's worth!Yanmar doesn't build fresh and salt water versions of its engines because no one can ever say where the boats will wind up. I think all engines have internal zincs; my brand-spanking-new-damn-near-cost-me-the-ranch Bukh replacement for that boat-anchor-bound stock YSM-12 (actually, I donated it to the Sea Scouts) had a big ol' one in the head's water jacket. I suggest you dig out the operating/service/owner's manual and take a gander at it. There should be a big ol' hexagonal plug in the top of the engine near the thermostat and the heat sensor. That should be the plug into which the zinc screws and then is held in place inside the water jacket.Now, for all you hydrophysicists out there, fresh water is NOT as conductive as salt water, so, no, you will not experience the kind of electrolysis one typically finds in "my" kind of water. However, you can develop electrolysis by just having two dissimilar metals including metals of the same type, but different alloys in contact with one another and bone dry! You can also have what's known as a "DC leak" aboard your boat -- electrically bonding all your fittings is a good idea here -- and the DC current will eat your prop right off the boat. If you have brass/bronze components in contact with other metals, look to see if your brass is turning a kinda weird pinkish color. If you do, you go electrolysis coming from someplace. You can use a good -- I prefer Fluke -- multi-meter to check for errant current. If you have something like this, then having zincs in place will protect you even in fresh water.It never hurts to have 'em; they are relatively cheap and don't forget your rudders since the rudder posts and bearings are susceptible to electrolysis as well.Ok...go ahead...throw bricks at me now if you must!!!Regards to all.
