Here is diagram. The drains with dark arrows are the ones for coolant as described by Kloudie, the other one being the seawater drain.Should be a drain cock under the heat exchanger/exhaust manifold and another on the block on port side aft of the oil filter. The one that is at/close to the exhaust ell is a seawater drain cock.
Claude,Here is diagram. The drains with dark arrows are the ones for coolant as described by Kloudie, the other one being the seawater drain.
Sorry. I found itClaude, Thanx. Could you try attaching the diagram again?
I will change mine this year. The engine is a 3GMF (22HP 3cyl).Spoke to a Yanmar dealer today. He told me there is no point in changing the coolant. "You will probably ned to change it on a car maybe every 5th year, but probably never on the engine on your sailing boat." Any views on this ?
