Happens more often when engine is hot. Last year I'd keep in gear through mooring field because drifting in crowded mooring field = not fun. She doesn't skip once engaged. Boat is currently on hard & I'd like problem resolved before spring. My research so far has said.
1) Shift Cable and Linkage Adjustment (Most Common) I'd hope this one is right, seems like easier/cheaper fix.
2) Transmission Oil Issues- Possibly, marina handles engine oil changes, I suppose I could check this even in off-season, maybe taste oil or apply to a salad.
3) Worn Cone Clutch -This seems like a complex repair, engine was built in 1988, I'm' not sure where to start.
Any thoughts or has anyone done this dance before & could summarize the steps. Thank you.
