Yanmar 3GM30 oil leak
Jul 4, 2015
436
Hunter 34 Menominee, MI; Sturgeon Bay WI
Hi;
Anyone experience a leak on the fuel pump side of their engine?
Tightened down the fuel pump bolts and replaced gasket but is coming from somewhere that side of engine based on where is dripping onto floor pan and hard to see in that area with the compartment wall obstructing view. Any similar encounters?
Thanks. Ilan
Feb 2, 2006
470
Hunter Legend 35 Kingston
Could it be from the pump? The diaphragm can develop leaks with age, and can result in drips coming down the side of the actual pump, and then down that side of the engine.
Chris
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
I replaced the lift pump this year. It was a great fix to the problem of always having fuel oil underneath the engine smelling up the boat and dripping into the bilge.
Nov 6, 2006
10,115
Engine oil, right?
There are a few places it could be leaking from. The dipstick seal, the dipstick housing, the fuel pump base, and the two "banjo" connectors that supply oil to the camshaft bearings. A banjo bolt may have loosened and is dripping.. be careful tightening since they are not that difficult to break. It may be necessary to change the copper gaskets to get the leak to stop, if that is where it is leaking. To see the connections, find the little pipe that crosses the aft end of the cylinder head and follow it around and under the exhaust manifold. You may need a mirror and flashlight.
Jul 4, 2015
436
Thanks for advice. Will be pulling away cabinet side to inspect closely.
Nov 6, 2006
10,115
Shouldn't have to pull that off for access; it will help but.. you can reach up under the manifold with a paper towel and feel for the banjos .. one leaking will weep onto the paper.. wait till it is cooled off..
MitchM
Jan 20, 2005
1,031
check out this thread , then call Bob at Niemec marine, the yan mar gold dealer in new bedford MA...
Hey, Yanmar Mechanics! Fuel Lift Pumps ! - Cruisers & Sailing Forums
www.cruisersforum.com › ... › Engines and Propulsion Systems
Mar 24, 2010 - 15 posts - ‎7 authors
It might be just the fitting that is leaking, but with a 20-yr-old boat ... I read an article lately in GOB about a 3GM30F with a lift pump that leaked ...
Yanmar 3gm30f - Occasionally sputters and dies on start ...
Jan 5, 2016
Yanmar 3GM30 Oil Leak
Sep 9, 2014
Replacement Of Fuel Injectors For Yanmar 3GM30 - Page 4
Sep 23, 2012
Yanmar 3gm30 Water Pump
Jan 10, 2009
More results from www.cruisersforum.com
