Tom
I have a Yanmar 3gm30f 1984 with 475 hrs. It has a vibration that's driving me nuts! This is an engine vibration that only manifest itself at certain rpms. Smooth as silk to about 1200 in or out of gear. Vibration increases with rpms to about 1800 where it smooths out. (or reaches resonance) The motor itself is not vibrating/shaking much, but everything else on the boat is! First, I thought it was a drivetrain issue, but since it still did it in nuetral... Anyway, I removerd the transmission, as I had blown a rear tranny seal a while back and thought maybe I had warped a plate. Vibration, if anything was worse. (with the tranny removed) I had the injectors checked. One bad so it was rebuilt. Ah ha I thought....No luck. Engine runs better thus making the vibration more noticeable! Engine mounts. With motor running and vibrating I pried up on the mounts to see if maybe I had a bad mount. Prying up on the port rear seemed to help so I pulled it. Was in perfect shape. I called to see how much a compression check would be, $140.00!!! I have the tools to do this for an auto but not diesel. What do I need and where to buy a compression set for diesel? Should this be my next step? I'm thinking maybe a valve issue???ANY HELP WOULD BE APPRECIATED!ThanksTom'Hearts Desire'
