G
George Gore
I own a 90 35.5 with the Yanmar original and standard 3GM motor. It's been a reliable and good motor requiring only standard maintenance over the years. I note at start up/warm up, the valves really rattle and this subsides as the motor warms up to operating temp. I think this is normal, but may be more pronounced as the engine ages and an adjustment my be overdue. I have looked at the manual and it gives info on adjusting the valves; however, if someone has made this adjustment, I would like any hints and tips. I suspect that it will require a new valve cover gasket and am concerned that there may be other items I should pre-procure before I start the procedure. Any help would be appreciated.
