if your shaft is in good repair then all you need is bearings and seals ....so i suggest you take it apart and get the bearing numbers and the seal numbers and go to a supplier dealing in bearings and seals and have them match them up and reassemble it ......i think you said you had a new empeller and gasket already ...if you have any problems give me a call....
Did a better job of sanding the corrosion off of the impeller cover. Put in a new impeller+gasket and ran the pump with my cordless drill. Works great now! No leaks either.
