G
Guy LeClair
Hello all,I have the 13 hp 2GMF which overheats after 30 minutes at about 2800 RPM - so far I`ve cleaned the heat exchanger, replaced the sea water pump impeller (the pump still leaks 2-3 drops per second - I still have to replace the seals) cleaned the sea water strainer... I`ve got a spare thermostat which I`ll change next, and do an oil change ( I bought the boat in April and do not know the age or quality of the motor oil)... any ideas as to the cause of overheat will be greatly appreciated,Guy
