Hey there sailors.
Im looking to do a coolant flush and change on my 13hp Yanmar 2GMF engine. I'm not sure what type of coolant is in it currently but it def needs a flush.
Question, To flush I drain the existing coolant and fill with new stuff. Run the engine for a bit with the radiator cap off until I see steam then cut engine and drain again. Correct? I repeat this a few times if I wish right?
As for what coolant to use, is 50/50 prediluted long life coolant I can get from auto store sufficient? Any recommendations?
Thanks so much.
Thanks so much.
