Doug
We start and shut down our engine as specified in Yanmar's owners manual. That is to say...we give full throttle to start and then back off immediately. And to shut down (after 5 minutes at idle) we give it full throttle and then pull fuel cuttoff followed by turning off key once it stops. My question is..how much black (or dark gray) smoke should emit from exhast when we do this. It does not start hard (fires right up every time) nor does it smoke while running but at start and stop it gives us a bit of a cloud. Is this normal? We get good water flow so I would believe our mixing elbow to be clear. You veteran Yanmar/diesel users out there could probably help me, I hope.Also, for your 1988 33.5 owners, do you notice that with more than one person toward aft end of cockpit that the exhaust through-hull is under water (bottom couple of inches of transom) and that you hear bubbling as if water is blocking exhaust. Could this cause problematic backpreasure? anything to worry about? It seems Hunter put that exhaust exit in a precarious position. Let me know please. Thanks.Doug
