[Please see attachment photo]
My 2GM20F fuel injection pump is seeping diesel when the engine runs. It is not that excessive, but enough to make things reek of fumes. This has been going on for quite a while and I temporarily fixed it by re-seating #12 a while ago. Well, it is back, worse than before.
Without taking the whole thing to a shop for a rebuild (sailors are frugal), I was hoping that someone has experience taking these things apart enough to assure me that if I remove #12, parts won't spring all over my engine compartment [grin].
According to the parts diagram:
#13 is an o-ring (I'm hoping THIS is the issue)
#10 is a gasket
#6 is a gasket
Questions:
1) Can I safely remove #12 and replace the o-ring (#13)?
2) Can I also replace #10 and/or #6, or are these integrated into the plunger
My goal is to just stop the leaks. Other than this, the engine runs perfect.
Thanks!
#10 is a gasket
#6 is a gasket
Questions:
Thanks!
