Yanmar 2GM20F Fresh to salt conversion?
3
Hunter 28.5 Guntersville
Can a fresh water cooling system be converted for use in salt water? Cost? Difficulty?
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
Your 2GM20F can be used in salt water or fresh water or anywhere in between. The raw water cooling system doesn't know the difference. The freshwater side will have antifreeze and is a closed system.
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
Big question is...WHY? The system is pretty foolproof AND bulletproof as is...why monkey around with it?
Dec 2, 1999
15,184
I agree, why would you want to do this. It will just open up other maintenance questions that you would probably not want to deal with. You would probably not be able to heat water and your engine would not run as efficently.
Jan 2, 2005
779
drharvell...maybe we missed part of your thought process...you DO understand that your Yanmar is also cooled by the "raw water" it is sitting in, whether it is fresh or salt? No worries about moving it from fresh on your lake to salt in the Gulf or elsewhere...no "conversion" necessary.
