Hi All,
My hunter306 has a Yanmar 2Gm20F and has given me starting issues for the past weeks but now just refuses to start.
We checked voltage at battery and starter which is all good. We checked voltage at the starter when turning the starter switch/button over but get nothing. I replaced the Lewmar engine control (non magnetic single lever) with the same results.
The first Engine start after installing the new Engine Control was successful, she started right up. Subsequent starts did not work. Played with the lever taking it out of neutral, shifting it, then placing in neutral to start but nothing.
The engine control (both old and new) have a Neutral safety switch built in but there are no cables running to this switch.
Question is where is the Neutral Safety Switch or How does the lewmar engine control and the Yanmar engine control the neutral position?
