Hi there.3Hurricanes and 5 weeks later, I went out for the first sunday afternoon sail.After I recharged my dead batteries the Yanmar diesel finally started.Short time later I noticed that I could not run higher then 2200 rpm in gear.After I disconnected the gearbox, I was able to run up to max. 3400 rpm just fine.With the engine in gear, nothing happened after 2200 rpm, increasing throttle resulted in black exhaust. So I ran the engine at 2000 rpm and barely made 4 miles an hour. I kept the engine on for the afternoon trip and the problem persisted.Before all that Hurricane trouble the engine was working just fine. What is your best guess ? Where should I look first ? Moisture in tank ? Fuel filter ?I am not a diesel Mechanic.Thanks for any help.Siggi
