yanmar 2GM 18hp charging light glow
IgorC
Apr 12, 2008
18
Hunter 29.5 -
On my Yanmar diesel the charging light come on. I have tightened the belt and it seems to fix the problem. However, when I was motoring in the dark I have noticed that charging light is still glowing slightly is only visible in the dark. I check charge on the battery and it was around 13.8V so i think alternator is working fine. I am not sure if the problem is with belt and I have to tighten it even more or the problem is with alternator. Any ideals or suggestions?
Grizz
Jan 13, 2006
179
Hunter 28.5 Park Ridge, IL
Same engine, slightly different condition
My charging light will glow if/when I pull the key while under power (old habit to prevent the key from being snapped in half by an errant foot), but won't glow if left in and in the 'on' position. I've given up trying to figure it out, 'cause the batteries are charged (the volt-meters tell me so!) and it doesn't appear to be broke, so fixing it won't improve anything. Good luck w/ your gremlin search!
Nov 28, 2004
209
Hunter 310 San Pedro
Weak Warning
Igor, You may have corrosion on the lead to your sensor. Check the leads for high resistance. It could indicate internal (under the coating ) corrosion of the lead wire.
IgorC
Apr 12, 2008
18
Hunter 29.5 -
light glow
Grizz, You are right it work the same way for me. If I take out key charging light start to glow if I leave key in start position lights goes away. I think I can stop worry about it. :) Thank you for responses!
