On my Yanmar diesel the charging light come on. I have tightened the belt and it seems to fix the problem. However, when I was motoring in the dark I have noticed that charging light is still glowing slightly is only visible in the dark. I check charge on the battery and it was around 13.8V so i think alternator is working fine. I am not sure if the problem is with belt and I have to tighten it even more or the problem is with alternator.Any ideals or suggestions?
