Time for Hunter/Yanmar to come clean
There are two sides to this story. One side is presented in an answer to your question. It leaves one with the impression that, Yanmar is to be blamed for the overheating, purportedly because of cosmoline - whatever that is, being left on the heat exchanger coils when engines were shipped in crates to Hunter. As you have read, this stuff gets baked onto the coils and in turn reduces the flow and cooling efficiency of the heat exchanger. Yanmar for its part (through its representative)told me the engines are shipped dry to Hunter and coolant is added not by Yanmar but after shipment. The Yanmar rep claimed that, unfortunately 100% coolant concentrate was put into a number of engines, which intially caused those engines to run hot and therefore overheat. He told me as the engine overheats a silicone residue from the 100% coolant is left on the coils that reduces the flow and efficiency of the heat exchanger. You will see from the archives that, engines that are subsequently flushed out and refilled with new (and correct 50/50) water/coolant mix and also had the heat exchanger properly cleaned or replaced, appear to go on to operate normally.It is pretty subjective whose story you believe since Hunter remains mum on the subject. Having had my 2004 Hunter 33 'done' by Yanmar and witnessing the blood-red colour and resultant breakdown of the normally pink coolant, I tend to believe the Yanmar version. At a point during my overheating problems I had to keep topping up the coolant level and replaced over 2 litres of coolant over the course of the experience. That did give me some respite from the continual overheating. I can only guess it was because the coolant concentrate was obviously reduced from the reported initial 100% level. Nonetheless, I am convinced that, the subsequent overheating was caused by the silicone residue blockage that Yanmar said settled on the coil. Anyway, from my personal experience the use of the 'wrong coolant explanation' is not inconsistent with some of the shoddy workmanship on my 2004 Hunter 33. The other reason I believe the Yanmar version is that - in my case anyway, the heating problems began after about 20 hours of engine operation which in my view tends to be more consistent with the coolant 'residue' story because it takes a while for that residue to accumulate. The cosmoline blockage would have occurred much sooner if the stuff was already present on the coils.In any event, it is sad that purchasers of new boats from Hunter have not been alerted to this serious problem that the manufacturer is very well aware of. Purchasers bought these boats in good faith from Hunter not from Yanmar. Rather, Hunter leaves it to the individual owner to actually experience this frustrating overheating problem while operating the boat - sometimes in difficult circumstances - thereby possibly endangering the user and his new boat. That is unconscionable. I can only guess the chant is 'just keep pushing out these babies' - bent keels and all.
