2 GM(F) Water pump rebuild- Mushroom
I just rebuilt my water pump- Mushroom Laws in effect. 1) Replace the impeller & gasket. Still leaks!2) Call Torrenson Marine( First of 3 times) These folks are the best!!!!!Tapped the impeller shaft out and discovered that broken oil seal ring had allowed water to rust 1 of the 2 ball bearings. Ordered 2 ball bearings $7.00 apiece.3) Tried unsuccessfully to remove damaged ball bearings from imp. shaft. Damaged the shaft! Call Torr and layout $95.00 for new shaft & V pulley.4) Re-assembled! Keep in mind that the oil seal ring needed to be jymmied into place at the 2 vents with a flat head as assembly did not have it in its optimum position.2 things to noteMACHINE PRESSThe guys at my marina had a press: no other way to replace ball bearings.Period.CIRCLIPThere is a circlip between the 2 ball bearings. It is not shown on the Yanmar manual. Luckily, I was able to salvage it from the old shaft.I am now a water pump expert and even though what I thought was a quick fix became an endurance test, it was fun to solve.I mention about the press because small leak & no maintainence > 2 years, that ball bearing is not gonna be fun or wanna let go from the shaft.To remove the pump, undo the 2 long bolts which suspend the pump away from teh engine and then loosen V-pulley lock nut: Then, the fun begins!Good Sailing!s/v LOTUS
