Anyone know anything at all about small diesel engines?
I had to replace a hose that ran from the engine to the domestic water heater on the boat. Of course a lot of coolant ran out. When I reconnected the hoses and filled that part of the water system, the engine started to overheat.
On this 18 hp Yanmar, there are two separate water systems. One for heating domestic water; this is a closed system which employs a heat exchanger of sorts and is the system that I was working on. The other water system is use for cooling the engine; this system takes water from the lake to cool the engine. To my knowledge, the two systems are not connected.
The engine has been run a total of 20 hours since I have owned it and it has never over heated. After I changed the domestic hot water hoses, the engine will get hot after running but a few minutes.
Anyone got a clue what might be going on?
Thanks,
Steve
Thanks,
Steve
