Yanmar 18 manual
G
Glenj
Does anyone have a service manual for a Yanmar 18 they would like to sell or do you know where I coud buy one? Need it soon to break in a new engine. Thanks
Jun 7, 2004
4
- - New Bern, NC
2gm20f?
If you mean an 18 hp 2gm20f you can get a yanmar manual from http://www.marinedieseldirect.com/yanmar/shopping/details.php?mfc=Yanmar&sku=A0A1361&prod_name=1GM10-3HM35%20SERVICE%20MANUAL If you want a clymer for lots less... http://store.yahoo.com/motobooks/yandiesinrep.html Hope this helps... James
Bill
Another source
Try Mackboring. They have service manuals, parts manuals, and training (through Engine City Technical Institute) if you're interested. http://www.mackboring.com/
Ed A
Sep 27, 2008
333
Hunter 37c Tampa
try the yanmar distrubitor in St.Pete
Mastry engine center in St. Pete is the regional distributor for yanmar and you can get almost anything you need right there. Its near tyrone square mall in st petersburg
Jun 3, 2004
347
Hunter 30_74-83 Lake Lanier, GA
Service manuals
Service Manuals are available from your local Dealer. They should run about $40.00. It doesn't give much info on care and feeding of your engine. What questions do you have about break in? Here are my general rules, Never allow the engine to run a constant rpm for extended periods of time, more then 10 min. Run the engine for a hard pull to full throtle for a run of 5 min per hour. Do this for the first 25 hours then change the oil and filter. Also change the trans oil at 25 hours. Pat McCartin Inland Marine Diesel Atlanta, GA
G
Glenj
Yanmar 18 manual-thanks
Thanks to everyone for the helpful advise with the manual. Yes, it's a 2gm20f. I didn't even realize there was more than on 18h.p. until I started following up your lead. And thank you Pat! Your tips will be most helpful. Glen
