Yanmar 1 GM Fresh Water Cooling
JCAL
Dec 14, 2008
81
Hunter 27, 1990 Lake Charles
Has anyone added a fresh water cooler system to this engine? If so where did you buy it? Jim
Bill O'Donovan
Why do you ask?
Is there a problem with the raw-water cooling?
JCAL
Dec 14, 2008
81
raw-water cooling
I have read there are less problems with fresh water systems, engines last longer, etc and am looking into the options. Any advise would be appreciated Jim
Mike
f/w cooling sys
F/W cooling sys is alot better as far as I'm concerened. you'll have to get a fresh water pump and a cooler with somekinda of mounting bracket, all the parts you need should be available at yanmar dealer, make sure you purchase all the zinks needed.. I work on boats as a side line so if I can be of any help feel free to e-mail me. mikemm@starband.net
Mike
f/w cooling sys
W
Ward
Good Yanmar link
Jim, I ran across some information about seawater vs freshwater cooling on the 1gm10 engine. It certainly has been converted, but the consensus seems to be that it was'nt worth the effort. See the link below and go to the discussion forum. Do a search on the 1gm10 and you will see several good threads on a variety of engine topics. Hope this helps Ward
W
Ward
Good Yanmar link
