I had an odd smoke situation today with my yanmar 2gm and was wondering if anyone can shed some light on it. I motored for about 45 minutes at 5 knots (~2000 RPM) to grab lunch. When we docked I think I only gave it about 2-3 minutes at idle before shutting the engine down (not thinking about the minimum 5-minute idle time). When we started the engine up to leave we had quite a bit of white smoke that continued at all RPMS, it is smoke and not steam. I have always had a small amount of smoke when i'm above 2100 RPM but this was a large amount of smoke at all RPMs. I shut the engine down and re-started and the engine smoked quite a bit less but still more than usual. My questions is this - do I need to investigate further or is it possible that one of the injectors was stuck open making the engine run rich? I guess this will be depended on the smoke it produces next time we go out....Just wondering if anyone else has run into this problem. Also, I checked the oil and coolant and neither show signs of contamination. Thanks again
