I have a 2-1/2 HP Yamaha four cycle outboard on my inflatable. Every year a build up of something that resembles tooth paste develops under the plate that the impeller sits on. The engine operates in salt water and I only flush it with fresh water at the end of the season. During the winter I open it up and manually remove the "toothpaste". Eventually the cooling flow would completely stop if I did not manually clean it out. It is just about blocked by the end of the season. Does anyone know of an additive that might dissolve this build up during the post season fresh water flush?
