I'm 5+ months getting a motor to Panama. Its a long story.
I really depend on a motor against 15 ft and sometimes 17 ft tide changes. I have to maneuver around moorings and cut across either a tide coming in or going out to get onto my trailer. I don't leave it in the water.
Now I discover that I don't have a full rotation range that I had with the old 2008 Nissan 9.8 that failed.
The motor tiller arm is the problem. I can't get a full starboard turn. If I could raise it up 2 1/2" approx. that could fix the problem but than I loose that 2 1/2" prop depth.
I could cut the hull away "maybe" but that's a little radical for me.
If I attached a bracket to the existing bracket moving the motor further from the transom I get a partial solution but then the motor tiller is a long reach and it may still hit the guard railing on the stern that the rudder tiller sticks through. In this case I could maybe resolve this by getting a "extension tiller that attaches to the motor tiller.
anyone else run into this problem and if so what was the solution?
thank you
thank you
