A
Andre K. 1991 Hunter 30
Hi Peggy!I have a question and I will try to be as precise as I can. I am on the process of installing all new hoses for the Holding tank. In the oryginal setting the tank outlet hose would be routed through the "Y" connector to the deck pumpout and the other end woud go through the macerator to the overboard discharge. My question is : is the "Y" connector Ok or i should replace it with the "Y" valve?Thank you
