XM Weather "Wind" Question
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
Happy (almost) 2010
Question?
Is/would XM Weather be helpful for long distance races? Aside from knowing when a bad weather front is coming, I am interested in knowing how up-to-date and accurate they measure the wind. For example, if we are sitting in a dead wind area and were able to view XM on a chartplotter where the better winds might be located, that would be helpful to our tactician...no?
If XM is not the correct option, what else is available to view live wind conditions.
Thanks
Tim R.
May 27, 2004
3,626
I have no experience with XM.
Unless there is an anemometer at the location you are interested in, all you get are predictions. Nasa has some satellite imaging that shows winds but on a large scale.
We have weather buoys offshore that can relay info via the internet.
Ross
Jun 15, 2004
14,693
You are seeking real time square mile area weather data. The only way to obtain that is thru on site observation. All wind and weather data are collected from point sources and radar images. Just as the soundings on your chart show bottom contours that are lines that connect a few dots. Weather maps are drawn from a collection of point sources and then predict the wind and weather patterns from that.
I just went to the weather underground private stations and checked their wind reports: 1 mile east of me wind SW @3, 1 Mile north wind SSE @ 3.5, 3.5 miles north west wind calm, 15 miles east wind ENE @4. At still pond 25 miles SE and on the water the wind is calm.
Dec 25, 2008
1,580
catalina 310 Elk River
Even with on the water anemometers, the wind 25' off the water can be dramatically different. If the water is cold and the air temp is warm, a cold layer of air will sit on top of the water causing decoupling.
Oct 2, 2006
1,517
Jboat J24 commack
You have to read you local rules as to whats legal to receive during a race under there OUTSIDE ASSISTANCE rules
It has evolved from VHF weather to some things BUT i believe PAY sights are still a NO at the local level of racing
Sailflow is very good in this area and open to all for free
For example on the J24 when in a PHRF event i can use GPS but if in a J24 event i cant use anything but a compass
Jun 6, 2006
6,990
XM only works close to shore
The satellite "footprint" is tailored to the US coast to increase the power to the land lovers. It only works a hundred miles or so from the shore then you loose signal.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
XM satellite is available all over the Caribbean and into Central America. The problem is going to be the available information regardless of where you pick up the signal. The info is pretty much collected from US sensors and radar images so other than US weather info you will get very little from this heading offshore. There are several weather broadcasts put out like those from Chris Parker and Herb Hilgenberg from SouthboundII that are available over the HF radio and weatherfax and grib files as well as text broadcasts can also be had via HF radio. There are also paid weather routers available for specific passages. Chuck
Oct 25, 2005
735
Catalina 30 Banderas Bay, Mexico
Happy (almost) 2010
Define "long distance race". As in a Trans-Pac? Then yes, weather information is good to have.
Get GRIB files for you area of the race (free via SSB or Internet). The software runs on a laptop and uses the boat's polars and the forecast/predicted weather to calculate an optimum route. The software looks at the route, compares VMC for headings +/- 45 deg and sets a way point 3 hours out based on the forecast, it does this for each 3 hour period until the end of the grib file. 12 -24 hour forecasts are usually pretty good, 24-96 hours less so. If you update your weather file every 24hr and rerun the routing software you should have an optimum heading based on 3 hour course changes.
The software was developed for the Whitbread. You can set the interval between waypoints and the range of headings the software considers.
It is not very useful for races under 24 hours or so.
I also have the Sirius Marine Weather service. The service is not free, but the data it provides *is* free. The XM Master Mariner product is about the same now that the two systems have merged. Since the data is freely available I don't see a problem using it while racing. It is not "outside assistance" in the same way a weather routing service is. All the data is from the same public sources (NOAA). Even though the Sirius system is built around US coastal waters, it does do some pretty cool stuff and it works at least to 18 deg S. After a couple of hours, it has downloaded a complete data set. You can then animate the forecast and see what wind, waves, or pressure are predicted to do. Again, the short term information is better than the long term. One of the things it does is give you a marine warning pop-up window for the sector you are in if one is issued. You can also read the text of the VHF weather broadcast for any selected sector.
The satellite weather stuff would be better than nothing for coastal ocean racing, but that is not what it was meant to do. For racing there are better options available. They become more cost effective when you consider the cost of the XM hardware and a $50/month subscription. You can download your GRIB files using your cellular phone, you probably have a laptop running XP, all you need is $600 worth of software and you are good to go.
The software I run is RayTech. It is an evolution of the KiwiTech software that the RTW guys used. I think you can download a demo version for free to see what it can do. You have to buy it before it will work with instrument data. It will interface directly with a Raymarine plotter, but does not require one. It will work as a stand alone with a NMEA or SeaTalk interface. For shorter races, having laylines and target speeds updated in real time is pretty cool. As is the TWA of the next leg on a buoy course.
None of these options give you real time wind conditions. If you want to look for better breeze in real time over a mile of two of race course, you need LIDAR ... that is getting into expensive toys ... :)
