Dan McGuire
At the risk of being severely flogged, I would like to broach a new subject. I am a retired engineer and engineers are notoriously bad writers, but some of the writing in this forum is unintelligible. The other problem is ”units of measure”.I would recommend the writers in this forum take the time to read what they have written. You have something to say and I want to be able to understand it. However, I don’t believe the ease of use of the internet should be used as an excuse for bad writing. If the choice is between not writing and writing badly, then write badly.The other problem is units of measure. The two units of measure, which are most misused, are “knots” and “amps”. A knot is equal to a speed of one nautical mile per hour. If you use the term one knot per hour then you are actually stating a change in speed or acceleration. The measure of current flow is simply “amps” or “amperes”. One amp is equal to one coulomb of current per second. An “amp-hour” is equal to 3600 coulombs of electricity or one amp of current for one hour. If you use the term ”amp per hour” then you are stating a rate of change in the current. If you use the term of one amp-hour/hour, I don’t have a clue what you mean. Again, I would rather hear what you have to say, even if it is not technically correct.
