Spongy foredeck
Hi there,First I dried the rotten balsa core by cutting a hole about 1.5" and suspened a hairdryer above it. I picked hot sunny weather and had the drier on low heat, high fan. I picked a spot that would later be covered by a deck fitting. Next i managed to vacume out some of the loose balsa.I bought 60ml syringes, meant for large animals, minus the needles and a medicine dropper for the hardner. Because of the climate, I am in Guatemala, I chose to use Polyester resin but you will probably get a stronger result with epoxy resin. I used codicil as a filler because that was what was available but my choice would probably have been micro balloons. Don't forget to have plenty of gloves etc.You will need to experiment as to how much filler you can use and still squeeze it out of the syringe and also what size drill bit you need for the holes to inject through.I started from the edge of the deck so that the resin would back up from there. I found that it was necessary to let one lot start to go off before injecting the next lot otherwise it started pushing out of the earlier holes.I am at the cosmetic stage and will hollow out the injection holes a little and fill with white resin paste of some sort. I think the reult is about 90/95% good. I am thinking about trying to squeeze a little more in, perhaps just the resin with no filler.
