Working jib or genoa
10
Balboa 20 Long Beach
I am re-fitting a Balboa 20. It does not have any sails. I am looking into purchasing a suit of sails, but can only afford one head sail right now. My question is, should I buy a working jib (90%) or a genoa (150%)?
Thanks,
Tom
Apr 15, 2011
22
Hunter 34 Lake Ouachita
Is it a roller furler or Hank on? If it is roller, I would go with a larger genoa and sail with the option of reefing down. If it is a Hank, and I could only buy 1 sail I would probably go with a 100 or 110.
As a side note, I would weigh heavily what material and durability of sails within my pricerange, and I would choose the best out of all 3 criteria. Buy a cheap sail and you may only get a few seasons out of it, not to mention size doesn't always get you the speed you desire.
Look in the owners manual to see what they came stock with. The engineers that designed it probably had a standard sail or two they recommended.
Aug 1, 2011
10
Thanks for the feedback. It is a hank-on sail. The two sails that I mentioned are the two head sails from the original design. So, it sounds like you are recommending the working jib (90%)?
Tom
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
If you have a roller furler/reefer, I'd buy a 135 genoa. If you need hank-on sails, you can also buy the same size sail that may also be reefed. Reefing a hank-on sail (designed for it) can be a chore, particularly if sailing solo, but such a sail will give you greater flexibililty to sail in a variety of conditions.
I agree that you generally get what you pay for in sails: buy the best quality you can afford. You may also want to try some of the used sail brokerages/lofts (i.e., Bacons, Minney's, Atlantic, etc.) as you sometimes can get a good quality sail at half the price or better than a new one. If you go this route, make absolutely sure of your measurements and make sure you can return the sail if for any reason it does not set correctly on your boat.
Rick D
Jun 14, 2008
7,206
It depends a lot on where you are sailing. For Long Beach, if you mean California, I'd stick with a 110 or even a 100 since 20 knot winds are common. If you are thinking elsewhere and want a tad more area, think a 130.
BTW, don't forget to check with Minney's Marine Surplus in Newport. They sometimes have new or near-new sails that might fit at a large savings.
Aug 1, 2011
10
Long Beach, Mississippi. So, I will usually be day-sailing and over-nighting in the Gulf of Mexico around the barrier islands.
Tom
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
My question is, should I buy a working jib (90 %) or a genoa (150%)?
If you absolutely can't both right now, I am going to recommend getting a GOOD 90 to 100% working jib first:
- it's cheaper than the genny,
- easier to handle, especially if you are still learning
- a 150% genoa can be used from 0 to maybe 15kt max, depending on point of sail; the working jib will work from 0 to 20+ kt
You can defer the genoa purchase to when you want to get the last kt of speed on a light-air day.
Jul 1, 1998
3,062
What's another recommendation?
Here's my two cents:
It's been mentioned to consider going with a used sail for the jib and I'd second that. Most used sails are going to be for roller furlers so finding a GOOD used hanked-on one will be a little tough. Narrowing it down to the dimensions you need will make it a tad more difficult but there is probably something out there you can use. Check the sail for draft, too.
A larger used sail could be cut down but this runs up the cost. A hanked on sail will like a sail bag for storage.
Reasons for going used: first is cost. Second is you'll really want to get a roller furler at some point. Maybe a third one is to save some money to get the one you really want.
Make a scale drawing of your rig which includes the deck and the genoa track to see how the sheeting angle will be.
Size: My preference for starters is for something in the 110 range as this provides a bit of overlap. As the sail starts getting smaller it will loose some of the performance. Be sure to put some telltails on it. Talk to other locals with a masthead or fractional rig like yours and see what they have to say about what percentage to use.
For a new working jib sail I'd suggest seeing where the sailmakers proposed sailcloth fits in the measurement size range and if it's on the low end then consider going with the next heavier weight cloth. Cost-wise it won't be much more but it'll last a lot longer before getting blown out.
Joe
Jun 1, 2004
8,339
Get a 110% headsail, medium weight dacron cross cut, say 4.5-5.5 oz.. Dacron, cross cut Mainsail, loose foot, with full roach, top two battens full length and two reef points.
Rig a downhaul for the jib so you can control the drop from the cockpit.
The full roach main will give you a little extra power to compensate for the smaller headsail. Two reef points allow you to depower without messing with a headsail change.
Jun 16, 2010
495
In search of my next boat Palm Harbor, FL
On a small boat like yours, build yourself a PVC furler, and get a hank-on 135 or a 150. The po of my H22 had both a jib and a 150 genny. I took the hanks off the 150, and built a PVC furler... Cost ~$50.
Jul 29, 2010
1,392
Macgregor 76 V-25 #928 Lake Mead, Nevada
Great choice on the Balboa 20. Most boats out of the factory come stock with a standard jib. You might think about checking some of the big sailmakers like Hood or North. They have good used sails at decent prices. Also check Balboa owners site. sometimes you might find a deal. Good Luck, Fair Winds and Full Sails....
Dec 27, 2009
82
Clipper Mariner - Mac 25 -Bayliner and 4 kayaks 21 Clipper & 25 Macgregor & 19 Bayliner classic Red Rock Lake IA
OK, for those of us who have hank on sails, how do we build a furler for $ 50.00?
Jun 16, 2010
495
The o'day and compac forums here on SBO are full of posting and articles on how to build one, as well as many sites if you google. Sorry, but I can't search for some of the postings right now from where I am at.
I can also dig out some of the pics of how I built mine... But basically it's sections of 3/4 or 1" PVC glued together in sections that match the length between eyelets on your sail. The sail is attached to the PVC couplers. At the bottom you build a drum for the furling line. The forstay is passed down through the PVC and reattached as normal. Pull the jib sheets to let out the sail, and the drum picks up the drum winding line. To furl it back up, pull the furling line.
Aug 1, 2011
10
So, how long have you been using this furler and how has it held up? Sounds like a great idea. Thanks for the suggestion.
Tom
Jun 16, 2010
495
I have use it about a year, although in FL we don't sail too much June to August (too hot). Even though my H22 is a trailerable boat, the po didn't have the trailer, so my boat sits in a slip year round. My genny doesn't have a sacrificial strip, my wife made a sock for it.
Aug 1, 2011
10
Thanks for all the advice
Thanks,
Tom
I just wanted to take a moment and say "Thanks". I got a lot of excellent suggestions and recommendations. I really like the homemade roller furler, but it looks like a 90 - 100% hank-on is going to be the winner for now. I found one that I can get for a good price through a reputable online dealer with a money-back guarantee.
Thanks again and good sailing.
Tom
Doug L
Sep 9, 2006
80
South Coast 22 MI
If you look on youtube there are a lot of videos about making a furler.
If you keep your boat in the water, a furler is great. A furler and a 150 Genoa would be the way to go. However, if you trailer your boat, and raise and lower the mast each time you use it, the added weight of the furler with sail may be the difference between raising the mast using just brute force and ignorance, and having to use a gin pole setup. Take note the guy in the Good Old Boat article is using a gin pole.
For a boat that has to go off, and back on the trailer each time you use it, my choice would be to stay with the hanked on sail, to make raising and lowering the mast as quick and easy as possible. And if I were to go with a single jib, it would be the working jib.
When I went from a Venture 222 with hanked on jib, to a Mac 25 with furler, I was unpleasantly suprised how much harder it was to raise and lower the mast.
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
If you are not going to race and have a roller, get the 150. On light air day you can use it all, on heavier air days, you roll it up to what ever works.
