Butyl tape
It may be the same thing that Stu is talking about, i don't know; but my research at the time, two years ago, was that butyl tape is the correct material for this job. It is available at RV dealers adn parts outlets. It comes in black or white, I'm told, 'though I could only ever find black. I would have preferred white. It is a material that is extremely easy to handle, has a good shelf life. Its a lot like putty. I used it on the aluminum lights in the C36 coah roof. This is the material that Catalina used originally. With some experience, I found that splitting the 1" wide stuff and only using half made for a better fit. You apply it to the sealing surface of the port, without stretching it, and only very slightly overlapping it, if not butting it, where it meets; make it meet at the bottom.When the port is tightened the stuff flows to seal and fill voids. jv
