Please forgive my question.. what is the best way to remove a wood plug
from a piece of wood....i.e. toe rails, misc. wood on boat that needs to be
re-bedded, etc. thanks for your help. Patrick
I use a brad point drill bit the same diameter as the plug and slowly drill it out. If you go too fast you will hit the screw head and booger up the slots. I like brad point bits since the center point makes it easy to center the bit on the plug, plus they are made for boring precision holes in wood. You just need glue and a dowel to reinstall them. Cut the dowel with a small hand saw and sand it flush.
I know folks who have used coarse thread drywall screws. Screw 'em in to the center of the plug, it will bottom out on the screw, and then augur up the plug. Or part of the plug. Finish up with a sharp knife blade so as to be able to re-plug.
